Removing multiple objects from VRayDistanceTex list
  • Removing multiple objects from VRayDistanceTex list
    Would be GREAT if we can CLEAR the object list one shot from the list, or at least select more than 1 at a time to remove.
    Gets annoying quickly if you have a lot of objects to remove
    Kind Regards,
    Morne
    Hi Morne,
    Apologies for the delay - this has been logged in our system as an improvement request under VMAX-10739; I'll let you know when there are any updates on the matter. Thanks!
    Nikoleta Garkova | chaos.com
      Cool, thanks Nikoleta
      Kind Regards,
      Morne
        While you wait, Morne , have a play with these:
        Instance your distance texture into slot # 1 of the material editor (this way, no need to write absurd amounts of code to find out what is what), then run this:
        Code:
        meditmaterials[1].objects = #()
        Conversely, with the map as top level in slot 1, select a bunch of nodes, and run this to add them all:
        Code:
        meditmaterials[1].objects = selection as array
        Lele
        emanuele.lecchi@chaos.com
        Disclaimer:
          Code:
          Code:
          Ah thanks Lele!
          Kind Regards,
          Morne
