UV Tiling attributes: LOCK ASPECT RATIO button to enable quick proportional changes (not having to change both U and V)
  • UV Tiling attributes: LOCK ASPECT RATIO button to enable quick proportional changes (not having to change both U and V)
    Often textures need to be resized, so a lot of testing for proper UV tiling size is necessary.
    It would be great to have a simple "lock ratio" button – enabled by default – similar to the button in the render settings for changing the image size.
    Almost always need to scale proportionally and only very seldom in special cases, you want to change the aspect ratio.
    If there would be this button, you could just quickly drag the slider until it fits perfect,
    instead of having this inconvenient workflow to type twice one value into the fields, then check the next value, etc.
    VOTE HERE: https://forums.autodesk.com/t5/3ds-m...idi-p/10084187
    Cool idea, I would like to see this too.
    As a workaround, you could connect a bezier float controller to both U and V tiling to link them together, but the one-click solution would be better of course.
    Simply, I love to put pixels together! Sounds easy right : ))
    Sketchbook-1 /Sketchbook-2 / Behance / Facebook
      You mean the ones in this rollout?
      Peter Matanov
      Chaos
        Exactly...
        you see it here in your own tutorials: https://youtu.be/tjDSC8pmoiY?t=56
        imagine you need a very exact size, it takes ages to find the value
        p.s. and if possible also have a look at the same in Maya
          Unfortunately, this rollout is controlled and generated by 3ds Max, so there is nothing we can do. But you can ask the Autodesk guys
          Peter Matanov
          Chaos
            Okay PLEEEEEASE VOTE here:
            Sad to hear, that this is under the control of the Autodesk guys
            They don't care very much when there aren't a lot voices.
            A single person could solve all those small requests faster than this company.
            My favorite hashtag for Autodesk #hireajuniorprogrammerforoneday
