Are there any way to make dragdrop map auto assign a Vray material..
+1 that would be great
also if it is possible to create vraybitmap if we drag and drop a map into slate editor ( there is a script for this but I prefer an official solution )
sorry if this is considered unrelated to the original wish .
Simply, I love to put pixels together! Sounds easy right : )) Sketchbook-1 /Sketchbook-2 / Behance / Facebook
Creating a V-Ray material when drag'n'dropping a texture is already possible if you use the Max.vray setting in Customize - Custom Defaults Switcher.
Yavor
thanks for your reply
Max.vray setting makes V-ray material and V-ray renderer default , but for drag'n'dropping , it still standard material and bitmap assigned....
is it avalible for max 2019 ?
