Please change default naming for Vray Renderelements - number has to be at the end !!
  • Please change default naming for Vray Renderelements - number has to be at the end !!
    Hello,
    every day I have to rename rendered sequences in order to be able to load them into software.
    It takes up so much of my time and is so annoying....
    "myfile_0001.origRGB.exr" is not readable as a sequence from any software
    - even not from your own new Chaos Player!
    (or other example "myfile_0001.VRayDenoiser.exr" )
    So I have to rename everything with special software, in order that the sequences can be properly loaded into a player or aftereffects or anywhere else.
    CORRECT IS THE NUMBER AT THE END
    "myfilename.renderelement-name.0001.exr"
    Everything else doesn't work.
    Hi how do you save your output? On my setup naming is just as you said -
    What versions of V-Ray and 3ds max are you using.
    Vladimir Krastev | chaos.com
      The raw file output indeed names them as Vladimir mentioned, but the REs are all in the same image.
      Same naming goes for the split save channel.
      Lele
      emanuele.lecchi@chaos.com
      Disclaimer:
        I am using the „expand # to frame number“ option and I always add a # at the end of name.
        Maybe I shouldn’t use this?
          If you just type the filename, from UI defaults, it will result in
          Code:
          basename.renderelement.framenumber.extension
          Lele
          Disclaimer:
