a VRay simple PBR material
  • a VRay simple PBR material
    Hello!
    It would be cool if it just needs images dragged into texture slots , and a untility let it can be convert to standard VrayMtl .
    I don't understand the request.
    The VrayMtl *is* PBR compliant.
    You want a unity shader converter?
    Lele
    emanuele.lecchi@chaos.com
    Disclaimer:
      Sort of , yes , like 3dsmax has a build-in [ PBR Material ] , It's says "Implemented as a scripted wrapper to Physical Material." ,
      I mean , a V-Ray verison, one material holds all images , easy to build , no Normalmap or AO comp node , color space settings needed.
      when you want to modify it , it shall be able to convert to VrayMtl , a converter will helpful.
        Scripted plugins are evil, i surely won't write an encapsulation of the vraymtl to simplify what's already as simple as it gets.
        Conversion to the delegate is also manual, nowhere implicit, and rife with potential issues.
        You're better off using the AD one, convert it to physical (they provide for the conversion to its delegate, right?), and then use the scene converter.
        Lele
        Disclaimer:
          I'm guessing you need something like this:
          https://dmz.gumroad.com/l/XOPH#:~:te...20a%20material.
          or this
          https://help.poliigon.com/en/article...don-for-3dsmax
          A.
          www.digitaltwins.be
            Thank you for reply, I understand. Stay away from evil all time ...
              Originally posted by Vizioen View Post
              Thank you, these tools are handy, yes
                Not *all* the time, there are necessary evils, unfortunately.
                A scripted material plugin, however, is truly the wrong way about it, I feel.
                The script would need to be loaded on any install that had to open the file, otherwise the plugin class wouldn't read, and *all* the data connected to the shader would be skipped.
                Given the relevant channels are all already inside the vrayMtl, the plugin would duplicate (some of) the original UI and UI names (diffuse, reflection), to no benefit whatsoever.
                Moreover, it'd have the user locked into the encapsulation, as there is no direct method that i know of able to extract the plugin into its costituent delegate shader (in other words, it won't automatically default to the original class if the plugin was not found.).
                As pointed out, it's better to have a scripted loader that plugs the relevant maps into the correct vrayMtl channels, so no class-breaking shenanigans can happen.
                The linked, free addon from poliigon seems to do a decent job, going about it the right way.
                Lele
                Disclaimer:
                  That make sense, a script material brings so many problem , that 's unnecessary .
                  The poliigon's addon is good enough to use.
                  Thank you for detailed explaining!
                    [ sory, double post ]
                    Marcin Piotrowski
                    youtube
                    CGI OCIO config 04
                      VRayPluginNodeMtl if you realy realy need it:
                      Click image for larger version  Name:	image.png Views:	0 Size:	63.7 KB ID:	1169780
                      Marcin Piotrowski
                      youtube
                      CGI OCIO config 04
                        That's for use in translation to standalone, though.
                        UI may or may not be pretty and/or functional.
                        Lele
                        Disclaimer:
                          ? Why not just use Max one. VRay will convert to VRayMtl under the hood in anyway.
