Ignore DR settings when netrendering
  • Ignore DR settings when netrendering
    When you submit a netrender, Vray should just ignore whether DR is checked on or not since it doesn't work when netrendering.
    Theoretically, this is just like Vray turning off the Max displacement setting when Vray Displacement is in place. That is to say, don't disable the DR controls and settings if netrender is checked. Let the user still play with things, but if the job is being netrendered, assume the state that DR is unchecked/turned off.
    seconded.
    Dmitry Vinnik
    Silhouette Images Inc.
    ShowReel:
      Also, if you have the framestamp turned on, it gets written onto every stripe when using renderstripes!
      This may be something that is impossible to control from Vray though since it works like any other netrendered jobs.
        Re: Ignore DR settings when netrendering
        Yes, I have this on my list, will try to implement it.
          Great, thanks Vlado.
