VRayMatID Pass
  • VRayMatID Pass
    Hello Vlado,
    Is-it possible to add a material ID pass ???
    In the next Sp ?
    Best regards
    My Flickr
    I've checked twice, and there is a VRayMtlID render element. Would have been very surprised otherwise. (As well as render and object id)
    Best Regards,
    A.
    credit for avatar goes here
      Ok...
      Maybe i'm blind...
      I'm using vray 1.5rc4 and it doesn't work at all ?
      Does it works with 1.5.00 sp1 ???
      Best regards... and sorry for my stupid wishlist request...
      My Flickr
        I'm using 1.5 sp1, and it work fine here. If I assign an ID to a shader it will appear in the VRayMtlID render element. Maybe you should give it a try with a more up to date build.
        A.
          You can also use VRayMultiMatte. It has a checkbox to use Material IDs instead of G-Buffer IDs. Works like a charm.
          Regards,
          Thorsten
            Regards,
            Thorsten
            Thanks... I will check that as soon as I switch to 1.5 final...
            Maybe one day... Dongles are sleeping on my desk... what a shame
            Best regards...
            My Flickr
              Regards,
              Thorsten
              Please help....
              Maybe i'm blind, I switch to vray 1.5Sp1 and I don't see the VRayMultiMatte !!!
              Were can I find it ????
              Best regards...
              My Flickr
                it's the first on the list: MultiMatteElement.
                  Ok thanks... Now hows it works... I use an overide material over my scene, i try to put ID 101 into the red channel... and no result...
                  allways black... is there a limitation ???
                  Best regards...
                  My Flickr
                    in the multimatte rollout check red gbuffer on, default id is 1, you just have to make sure your mat's id matches the multimatte's.
                    even though I'm not sure I see the point of using it with a single mat which overrides any other in scene.
                      http://www.chaosgroup.com/forums/vbu...278#post367278
                      Best regards...
                      My Flickr
