render image after irradiance map
  • render image after irradiance map
    is there a way to render the irrad map but not the frame (for when I'm creating the Irrad. map) I want to render a final quality later so I really don't need the renderings when I'm using incremental add (except to maby check eatch frame)
    at the moment I have the settins:
    AA fixted rate (defult)
    image size half origonal
    Min/max to sample more the full size image (ends up being the same size)
    the idea is that I can create the Irradiance map faster if I didn't have to render the frame after it.
    An old V-Ray trick is to under sample the AA with adaptive at -4/-4 for the imap pass
    Eric Boer
    Dev
      Thanks RE.... I guess at the moment that's about all I can do
        I agree it would be nice to render the solution by itself
        Eric Boer
        Dev
          "render the solution by itself"
          thats the language I was trying to use
            How about rendering the IR map over several computers, not just one. That would be nice.
            -k
              -k
              Actually I think thats in the works but they have to get the rest running first
              -dave
              Cheers,
              -dave
              ■ ASUS ROG STRIX X399-E - 1950X ■ ASUS ROG STRIX X399-E - 2990WX ■ ASUS PRIME X399 - 2990WX ■ GIGABYTE AORUS X399 - 2990WX ■ ASUS Maximus Extreme XI with i9-9900k ■
                and what about filtering maps? are you going to get a difference if you check off filter maps (but leaving maps checked)?
                that would be great
                  You mean?
