I don't know what it means the focused checkbox.
What's that?
And I found that render progress dialog stop when after cancel the render or prepass. So I have to terminate max and restart it. Is this a bug?
it hangs most of the time, i would call it a bug, but it also can happen without stereoscopic plugin, but it happens very much with it...
focus checkbox makes the camera toe in, so both are looking at the target
if not on, they are just parallel
i still havent found out what is "better" toe in or not, sometimes it is nicer for the focused part, but doesnt work so well for the background
toe in changes the perspective more, than just having parallel cameras side by side, but most often it works quite well
jes, and they work very well, excellent stereo renders!
most people do too much seperation, less is always better, and you have very minimal seperation but it still works!
would love to see a close up of the trex and his ribcage
using DOF with stereo is also interesting, because what is too far seperated because object is too close for example, our eyes will actually blur themselves, so using depth of field has been a technique to create depth without stereo, but we should try it with stereo as well, it blends the parts of the image better that are too far apart which you couldnt see sharply anyways, and it directs our eyes to a point of attention
I dunno what was used in this case. I would just slap it together in nuke:
-Create Views for left and right
-Crop both left and right
-Add a OneView op and assign the left crop to the left view and the right to the right
-Add a JoinViews
-Make it a gizmo for easy re-use :P
