i would love to know what realy is better, everyone uses parallel, no distortion etc.
but at the same time, our eyes always focus on one thing, its very hard to understand it all correctly,
also the 6cm seperation, it only makes sense if we create huge panorama renders or show videos on cinema, our brains have learned 6cm distance for our huge field of view, but this is not given for small images...
for monitors or prints 1 or 2 cm camera sepeartion is more than enough, anything else will create too much paralax which results in ghosting and eye strain....
vlado, would it be much work for you to update stereoscopic plugin? "for noW" we just want to put correct resolution for single image so it just doubles it automatically at render time, that way I dont have to calculate each time and i can use better framing in viewport, small update, but effective nonetheless...
also, no other rig allows for the same use of light cache for both sides
please let us know if you can have a quick update by next week
if not i wont keep on asking you, i promise
i prefer to use your plugin over complex stereo rigs which make things unneccesarily complicated--
Make sure the plugin .dlo files are from today (January 25th), just in case you get a cached copy of the file from your browser/proxy. If there are any issues, please let me know.
Got it to work now
is the helper supposed to be aligned to the exact camera position?
When rendering thru a standard camera with SSS2 material applied objects rendering hangs to eternity at the last bucket
Is it possible to have both eyes rendered to separate images (including all render elements)?
For a real life production this is not useful yet but promising to be
I cant get it to work.
It is getting stuck at the end of the render (max2010, 64bit, newest vray).
And how can i access the settings of the camera?
I can see only the stereo settings.
But it works only with standard cameras and does not have the rendering speed advantages of the vray plugin.
The great thing is that you can get a realtime stereoscopic preview of the max viewport.
You need the nvidia 3d vision glasses and a two monitor setup.
The monitor on the other side of the command panel will go into stereoscopic mode.
It can also show your images in 3D directly after rendering, so you dont have to save the image and load in a stereo viewer.
you can render both stitched together, or combine them in an editing program
usually side-by-side format left right, that way you can even crosseye them if u like,
