A Quantized-Diffusion Model for Rendering SKIN and Translucent Materials
  • #46
    Perhaps, I gather the presets are done using fit data. It might be more intuitive to see what the curves are doing in several cases and work at matching the curves rather than as you say using a color swatch which can be visually misleading.
    Also just so I understand can you or one of the gang there post a sample file where the green OJ isnt the case? I really do want to get my head wrapped around how to eliminate it within the existing model.
    -Michael
    • #47
      How about this one? The settings are exactly the same as in your scene, and the material is still physically accurate.
      • #48
        That's the point - it's not really a color. If I knew better back then, I would have named it "scattering coefficient" or something. The scatter "color" represents the scattering coefficients in the volume for the red, green and blue wavelengths respectively. While it has three components and it's convenient to represent it as a color in the UI, it does not behave as other colors like diffuse, reflection and so on. If you put orange diffuse in a VRayMtl material, orange diffuse is what you get no matter how look at the material. However, since scattering happens in a volume, the light changes as it goes through the volume - what comes out orange at one end, may end up as green on the other (or blue, or red), depending on the material properties.
        Are we kind of in a situation similar to what metals do with reflection? As in different wave lengths reflect differently in a metal and similarly different wavelengths scatter differently in different liquids / sss mediums?
        Michael what is fit data? Is it similar to a brdf scan except for refraction / scattering?
        • #49
          So the pesky greenish tint bug is fixed now; one of the formulas for calculating the volume properties out of the sss color was wrong - it is also wrong in the original bssrdf paper that I followed
          • #50
            Wow congrats o.o
            • #51
              Hehe hopefully really fixed this time
              Original code:
              Fixed code:
              • #52
                Ahah, really ?
                www.deex.info
                • #53
                  Originally posted by bigbossfr View Post
                  Ahah, really ?
                  Well, you know how most papers usually have one or two subtle mistakes - a plus turned into a minus, or a ' sign omitted somewhere, can make a bug difference
                  • #54
                    I knew it!.. So will it be Skin material or Mtl 2 still?
                    Dmitry Vinnik
                    Silhouette Images Inc.
                    ShowReel:
                    • #55
                      Original code:
                      [ATTACH=CONFIG]12588[/ATTACH]
                      Fixed code:
                      [ATTACH=CONFIG]12589[/ATTACH]
                      This makes a huge difference vlado!
                      Dmitry Vinnik
                      ShowReel:
                      • #56
                        Congrats
                        I just can't seem to trust myself
                        So what chance does that leave, for anyone else?
                        CG Artist
                        • #57
                          WOW! That's awesome Vlado. Fixing everyone's code since 2001. Hehehehe
                          • #58
                            So in the latest nightly builds, there is an option in the sss material (in the Options rollout in 3ds Max, in the Extra Attributes rollout in Maya) called "legacy mode"; it is automatically enabled when loading old materials, to preserve compatibility, but is turned off for newly created sss2 materials. When this option is off, there should be no unwanted color shifts in the sss2 material. If you can test this and let me know if it works as expected, it will be very helpful.
                            • #59
                              Maya 2013 nightly too?
                              Thanks, bye.
                              • #60
                                Yes.
