Auto update Env map in RT
  • Auto update Env map in RT
    Copypasting from http://www.spot3d.com/vray/help/rt10...er_3dsmax.htm:
    Auto update bitmaps - if this option is enabled, V-Ray RT will try to automatically update the rendered image whenever one of the bitmaps used in the scene is changed on disk.
    Now I have a dream regarding this. What if I'd be able to paint a custom HDR-image in photoshop that affects GI, reflections and refractions. Every time I save the image, my vray RT rendering magically updates! I've set up the RT render window next to photoshop, so I'll get instant feedback.
    That would be so nice.
    I haven't been able to get this work with vrayHDR or basic bitmaps in environment slots, vraydome lights or geometry with vraylightmtl. Updating is tacky and requires restarting the activeshade render or some other actions. My wish is that one of these lighting methods would work as I described.
    Edit:
    Turns out that I was too greedy. I wanted to use other machines for rendering the RT also, so I saved the environment map to a server. Using this method locally seems to work with just a little lag.
    Using win7, 3ds max 2013 and vray RT 2.30.02.
    TD at http://brinkhelsinki.fi
    3ds Max 2013 with VRay 2.30.01.
    Win 7, Intel Xeon X5675, Nvidia Quadro 5000, 48 gb ram.
    So, the issue is that the "Auto update bitmaps" option doesn't work when the bitmap is on a network drive, is that correct?
      No real issue here as I can use local RT. It works very well with minimum lag. Maybe the updating is just _really_ slow from a network drive, but that seems, i guess, normal?
        Well, we use some Windows mechanism to get the change notifications - it could be that it is slower for network drives.
