Heya Folks,
Just to pop up some bits that've been discussed in different threads that would be useful:
- The improved Maya Light select element (eg being able to choose raw, spec and so on in the light select element) - I know this one'll eventually make it into the nightlies!
- A primary and secondary Raw GI element - Would be great for figuring out where there's issues in either LC or Irmap, plus handy for compers balancing things - this might be very memory heavy though? Even a primary element might be good enough so you could subtract the Raw Primary from the Raw GI to get the secondary? Is this a hassle with the primary gi taking in the secondary gi calculations though?
- Sample rate for Reflections and Refractions - As Vlado had mentioned in another thread - would be handy for optimizing sampling.
- Sample rate for lights - I think this is maybe less needed as you can tell the quality of your lights by the raw lighting pass, and having the option of raw light select would cover being able to check specific lights.
Much appreciated!
John
Much appreciated!
John
