Noise map support in RT / GPU
  • Noise map support in RT / GPU
    Will it be possible to support the Noise Map in RT using GPU rendering? I use the Noise Map in many different materials and without support, RT isn't useful to me. True, I could use CPU mode but the GPU is so much faster.
    We do have it implemented in the GPU code, but it's currently disabled as it made the whole thing run a bit slower. We have to try it again with the CUDA 5.5 compiler...
      Okay sounds good. Thanks Vlado. If it still causes a performance hit when you try it with the new compiler, maybe you can add a UI switch so users can optionally enable Noise Map support with the knowledge it will slow things down a bit?
        Maybe I'm hallucinating -- but is the noise map now working properly in RT?....
        Update: Nevermind -- I realized I was in CPU not GPU mode. Oh well...
