GI/AA settings per camera
  • GI/AA settings per camera
    In multi-camera, complex scenes (architectural interiors for instance), it sometimes makes sense to have different GI/AA settings per camera. Could there be some sort of link between camera and vray settings?
    Worth a debate on pros/cons maybe?
    Kind Regards,
    Richard Birket
    http://www.blinkimage.com
    Kind of a general thing - rpmanager or even scene states might be worth a look. Possibly Dave wortley's pass manager too?
      You could have working render presets for each camera. Even a script to save and load a preset pre-render for each camera could be something. You could even xref in everything into an empty scene and have your different presets managed that way. One preset per scene.
      Aren't scene states and state sets what this is for? I'm so scared of using these 'features'...
        I share your fear. When scene set states (or whatever they are called) were first introduced several versions ago, we tried them and they caused all sorts of issues. I cannot recall what exactly, but it was so much that we stopped using them.
        Kind Regards,
        Richard Birket
          I have serious trust issues after being stung by it just once...
            Shhh John... I can neither confirm nor deny these vicious rumours...
            Maxscript made easy....
            davewortley.wordpress.com
            Follow me here:
            facebook.com/MaxMadeEasy
            If you don't MaxScript, then have a look at my blog and learn how easy and powerful it can be.
              Related to this somewhat - MentalRay has/had a unique AA per object feature in an unexposed shader. Very, very cool. Allows you to have lower/higher AA settings per object or even per material, I believe. I used to use this a lot. Vray is pretty intelligent when it comes to working out which objects and materials need greater or fewer samples but having a manual "override" as such was pretty cool in MR. You could, for example, have a scene set up where tree objects such as Forest etc. have lots of samples but everything else has much less, avoiding needless computation on unimportant objects with low contrast, for example.
              Alex York
              Founder of Atelier York - Bespoke Architectural Visualisation
              www.atelieryork.co.uk
                It's being worked on as far as I know? It was something requested quite a while ago so it's probably in the queue somewhere.
                  If you save your render presets, you can use max's batch render to load them relative to specific cameras, and even use scene states (not state sets).
                  Check out my (rarely updated) blog @ http://macviz.blogspot.co.uk/
                  www.robertslimbrick.com
                  Cache nothing. Brute force everything.
                    We're on the verge of purchasing RPManager. I've considered it for a long time now, but never taken the leap. Hopefully it will help.
                    Kind Regards,
                    Richard Birket
                      Probably the best thing to do... it's GI/AA today, but tomorrow you might need different resolution, different materials etc.
                        Richard, send me a PM with your email.
                        Follow me here:
                          can't work without render pass manager these days.
                            Hello,
                            To be honest,different resolution per camera is probably the most obvious, and the most widely needed.
                            Nicolas Caplat
                            www.intangibles.fr
                            • #15
                              This might be possible to do with a maxscript callback, let me have a bit of a play.
