Vray 2d displacement to support UDIM displacement maps please!!
  • Vray 2d displacement to support UDIM displacement maps please!!
    Hi, as the title says, can we get it in Max please since it's already in Maya for a while... please.
    I really need it and a lot of peoples do to I'm sure, it's so much better for character the 2d mode..
    Thank you
    Does the cheat of using the composite texture and offset work?
      nope, it work with the other dubdiv method , 3d and subdiv but not with the 2d mode.,... I don't know why it's takes so long to implement in max...... while they have it from day one I think in Maya..
        nvm I didn't see 2d displacement there in the topic. Well why not use 3d?
        Dmitry Vinnik
        Silhouette Images Inc.
        ShowReel:
          2d mode is crisper for fine detail on faces for some reason!
            I think the displacement could use a little lover overall, especially considering mapping channels and such!
            Software:
            Windows 7 Ultimate x64 SP1
            3ds Max 2016 SP4
            V-Ray Adv 3.60.04
            Hardware:
            Intel Core i7-4930K @ 3.40 GHz
            NVIDIA GeForce GTX 780 (4096MB RAM)
            64GB RAM
            DxDiag
              There are some improvements planned in this area.
                Good to know!
                Software:
                3ds Max 2016 SP4
                V-Ray Adv 3.60.04
                Hardware:
                64GB RAM
                DxDiag
                  good to know, but when Vlado? I have a project that requires 2d displace to work with UDIM .. and also, BTW, I've installed vray 3.3 the latest release , I saw that you fixed the sss in raytrace mode when an object interact with it ( it was becoming green.. ) but I did a test and if I use an other sss mtl in raytrace mode crossing my main object with the sss in raytrace, the other object get the greenish bug.. but not the main object... when can we have a sort of prepass rate to blend these togheter ?
                    There won't be a prepass. Select both objects, open the V-Ray Object Properties dialog and set their "Raytraced SSS ID" parameter to some positive integer (like 1 or 2). It is important that both objects have the same ID (different from 0).
                      I did not knew that the SSS had this option now thank's.
                        any news on implementing udim support in 2d displacement? this option would really help in production
                        CGSociety portfolio
                        Website
                          Unfortunately not yet, but I will try to bump the priority of this implementation up.
                          Tashko Zashev | chaos.com
                            YEah! thank's ^^
                            • #15
                              Just stopping by to say that 2D displace with UDIM is needed here too looking forward for the implementation, thank you!
                              Noemotion.net - www.noemotion.net
                              Peter Sanitra - www.psanitra.com
                              Noemotionhdrs.net - www.noemotionhdrs.net
