"Diffuse amount" in vray object properties
Can you explain more what you are trying to achieve? What should happen if that Diffuse amount parameter is zero? Maybe you can achieve what you want by setting the diffuse color of the materials to black and then decrease the diffuse amount from 100 to some lower number.Last edited by Alex_M; 08-01-2016, 02:22 PM.Aleksandar Mitov
www.renarvisuals.com
office@renarvisuals.com
AMD Ryzen 9 9950X 16-core
96GB DDR5
GeForce RTX 3090 24GB + GPU Driver 566.14
I was just wanting more control. I remember being able to do it in Arnold (I think it was spec/diffuse/gi). I suppose I could take down the output of the diffuse map. It was nice to have it in one spot though.
edit: to answer your question, if the diffuse slot was zero I suppose the object would be black, but I wouldn't get that extreme. I'd only bump it down a few points for that final tweak.
