FrameBuffer - Composition layer tab
  • FrameBuffer - Composition layer tab
    Something like Photoshop blend layers. Imagine a rawlight as softlight, enhancing the shadows on render. Must be easy to create. Blend + opacity.
    Ty
    Archviz Designer. 2x 2990wx + 4x 1950x + 3x 1800x / Nvidia RTX GPU.
    3dsmax / maya / vray / corona / redshift / unreal / fstorm / arnold
    Vray light mix tamb?m, se vray 4.0 n?o conseguir isso, eu n?o vou atualizar e vou migrar para Corona.
      We are working on some updates to the V-Ray frame buffer that would potentially allow us to do this.
        I remember hearing about this major VFB update quite some time ago - could you give an estimate on the progress?
        Software:
        Windows 7 Ultimate x64 SP1
        3ds Max 2016 SP4
        V-Ray Adv 3.60.04
        Hardware:
        Intel Core i7-4930K @ 3.40 GHz
        NVIDIA GeForce GTX 780 (4096MB RAM)
        64GB RAM
        DxDiag
          Yes, will record a short video on this.
            Vladimir Nedev recorded a short preview of his work so far:
            There is still some months of work to be done though.
              Well, wow.
              It went ahead a wee bit since the last time i saw it...
              Nuke watch out, we're coming! XD
              Lele
              emanuele.lecchi@chaos.com
              Disclaimer:
                Awesome!!!
                Kind Regards,
                Morne
                  Wow, that looks like a lot of features...
                  Can you make sure to test the new VFB for use with super high resolitions (10k and above) and a dozen of render elements? To make sure that it still is smooth and responsive?
                    Wow that's quite extensive
                    A.
                    www.digitaltwins.be
                      I'm not sure anything short of a proxy system (a-la nuke, f.e., where the processing happens for the visible pixels, not for the source images) would be able to maintain speed and responsiveness as the number of pixels grew (squarely, at that).
                      Which would be awesome to have. XD
                      Lele
                      Disclaimer:
                        You mean navigating a high res image inside the new VFB will be slower then before?
                          For now, the new VFB works like the current one, it applies the color corrections to only the visible pixels.
                          So, the resolution of the image you are rendering doesn't actually matter.
                          What matters is the size of the VFB window itself, and how much you are zoomed-in.
                          Even with the current VFB, you can make panning quite slow if you enable all the color corrections.
                          With the new one, you are free to add as many layers as you want, so we will have to develop a system to calculate the layers in a background thread.
                          Greetings,
                          Vladimir Nedev
                            This looks incredibly advanced already and I am looking forward to using it! Nice work!
                            Software:
                            3ds Max 2016 SP4
                            V-Ray Adv 3.60.04
                            Hardware:
                            64GB RAM
                            DxDiag
                            • #15
                              Thanks for the clarification, Vladimir. Looking forward to what you come up with!
