Originally posted by OzBoz
View Post
[SOLVED] No floating license error
This is a sticky topic.
I'm having the same issue, even after following the steps above. I can confirm the processes noted are running on my system and are the correct version. Here's the console error:
13-12-2024 15:08:52:460 [V-Ray] Srv: Qt subsystem initialized.
13-12-2024 15:08:52:463 [V-Ray] Srv: Starting V-Ray engine.
13-12-2024 15:08:52:472 [INFO] Srv: Router started on port 53407
13-12-2024 15:08:52:473 [INFO] Srv: Listening for client connections on port 53407
Traceback (most recent call last):
File "E:\Resources\Blender\_Builds\_shared scripts_4.0\addons\Realtime_Materials\t3dn_bip\thr eads.py", line 66, in _emplace_timer
preview.icon_size = data['icon_size']
TypeError: 'NoneType' object is not subscriptable
13-12-2024 15:08:52:840 [V-Ray] Srv: V-Ray for Blender initialization complete.
13-12-2024 15:08:53:454 [ERROR] Srv: Failed to acquire GUI license. Error: Unknown license error (1005). (1005)
13-12-2024 15:08:53:455 [ERROR] Srv: Cannot create renderer, cannot acquire license. Error: 1005
13-12-2024 15:08:53:473 [ERROR] Srv: Cannot start renderer, could not acquire license. Current license status: 1
Originally posted by adam_morris View PostI'm having the same issue, even after following the steps above. I can confirm the processes noted are running on my system and are the correct version. Here's the console error:
13-12-2024 15:08:53:473 [ERROR] Srv: Cannot start renderer, could not acquire license. Current license status: 1- go to https://my.chaos.com/ and login with your Chaos account
- open Products > Active Products
- look for V-Ray for Blender, beta subscription
image.pngIavor Vajarov
V-Ray for Blender Developer
chaos.com
Yep the subscription is showing in my Chaos account:
But if I click Manage on the error message shown in Blender, it sends me to https://my.chaos.com/organization/li...#regular-login which then shows
I just tried the suggestion above and uninstalled all the Chaos products from my system, then restarted. As well as starting Chaos License Server from the Windows start menu.
No change to the problem with any of it.
hello i get this ... i dont know some time i did local and other intall it with remote and i got both waty this issue : can you please fix this or what should i do please! my email wich i receive beta abatipe this is email im logging ...Error acquiring V-Ray license. Error 10061: Unknown license error (10061)
Ok now that works. had to change the light node, remove the cycles/eevee node.image.pngLast edited by bharat_singh; 14-12-2024, 01:49 AM.
I have the same problem, and it seems all installed well but i got this errors from the console:
v3.jpgAttached FilesLast edited by smereces; 14-12-2024, 04:33 AM.
