V-Ray server is starting, try again in a few moments
  • V-Ray server is starting, try again in a few moments
    Hi, when I try to render I only get this message: "V-Ray server is starting, try again in a few moments" V-Ray VFB won't show either, what is the issue?
    Save your file and restart Blender may fix that.
      Hi hmercado, Did the suggestion from dan_grill resolve the issue? If not, please let me know so I can assist you further.​
      Daniel Kapsazov | chaos.com
        Hi daniel.kapsazov No the issue is still the same. I saved the scene and restarted blender but still get the same message when I hit render: "V-Ray server is starting, try again in a few moments" and the VFB don't show up either.
          hmercado I’m sorry to hear that you’re still experiencing the issue. At first glance, it seems to be related to a licensing problem. I have to ask—did you follow the steps outlined in the following thread?
          https://forums.chaos.com/forum/v-ray...-license-error
          If you haven’t, please give them a try now.
          Originally posted by yolov View Post
          [Update, Dec 11, 2024]
          Hello everyone,
          We have identified an issue with V-Ray for Blender that may have already affected some of you.
          You may have seen V-Ray displaying a “No floating license available” error, or in some cases you may have seen a Sign In dialog that wouldn’t do anything.
          The issue is now resolved and the V-Ray for Blender beta build has been updated to address the issue.
          If you have been affected by this, here's what you need to do to apply the fix:
          1. ​Download the updated build and install it.
          2. Start Blender
          3. Go to Edit > Preferences > Add-ons and make sure the V-Ray add-on is loaded (you can ignore any errors or dialogs at this time).
          4. Set V-Ray as the active renderer
          5. Go to the V-Ray menu > Chaos Account and sign out.
          6. Go to the V-Ray menu > Chaos Account and sign in again.
          7. Restart Blender
          Thank you for your understanding and we hope you enjoy the beta.​
          I’ll be waiting for your response here.​
            Thank you. daniel.kapsazov I have the latest beta build installed.
            When I go to the V-Ray menu > Chaos Account nothing pops up to let me sign in or out.
            You do not have permission to view this gallery.
            This gallery has 1 photos.
              Please see attached screenshot for the blender console I get all those errors when I enable the V-Ray addon
                Dear hmercado​, hello.
                We wanted to ensure that your CPU has AVX2 support (listed in our system requirements).
                ZmqServer has crashed possibly due to access violation.
                Could you please also check Windows Event Viewer > Windows Logs > Application. There should be an Error with description containing ZmqServer.exe
                If there is one, please send it to us. And check the AVX2 support (link to Intel website is added above).​
                TS
                Tsvetomira Girginova | chaos.com
                3D Support | contact us
                  Hello,
                  My CPU is XEON E5-2680V2 AVX support NOT AVX2
                  Does this means V-Ray for blender is not compatible with my system even using an RTX GPU?
                    Originally posted by hmercado View Post
                    Hello,
                    Unfortunately yes, AVX2 is required for V-Ray to work even when rendering using the GPU.
                    Iavor Vajarov
                    V-Ray for Blender Developer
                    chaos.com
                      Oh well!
