Triplanar Mapping Problem
    @JuhaW: Where did you find the Triplanar node in your screenshot? I updated the exporter, but I still can't find it. Thank you so much for the help.
    Logan
    Omnia Mutantur
    logan683@gmail.com
    Origin Genesis Pro
    -i7 4790K @ 4.5GHz
    -GeForce GTX Titan X @ +200 GPU, +300 Memory x2 non-SLI
    -32GB RAM
    -Windows 10 Professional 64-bit
      Add > Textures > Triplanar
      Win11 Pro 64bit, GTX 970, Standalone version: V-Ray Next 4.30.03,
        I found it. It's in Textures. But this is what's happening. And why would someone use the Triplanar node and not the Triplanar settings on the Image Texture node?
        Logan
        Omnia Mutantur
        logan683@gmail.com
        Origin Genesis Pro
        -i7 4790K @ 4.5GHz
        -32GB RAM
          Oh snap. So, I didn't know VRay 3.3 Standalone was released today. Thank you for your signature, JuhaW. It works now.
          Logan
          Omnia Mutantur
          logan683@gmail.com
          Origin Genesis Pro
          -i7 4790K @ 4.5GHz
          -32GB RAM
            Look post #7, not working with gpu, but node triplanar is ok with gpu.
            • #21
              Hey, bdancer, is there a way to make the Triplanar node work with Glossiness input on GPU? It works CPU, since it's good in the material editor window, but not on the mesh.
              I've tried all combinations of using Float nodes, but no go.
              Logan
              Omnia Mutantur
              logan683@gmail.com
              Origin Genesis Pro
              -i7 4790K @ 4.5GHz
              -32GB RAM
              • #22
                And is there a way to make the texture projection in the Image Texture node to work with GPU? Or do I not know how to do it? Thank you very much.
                Logan
                Omnia Mutantur
                logan683@gmail.com
                Origin Genesis Pro
                -i7 4790K @ 4.5GHz
                -32GB RAM
                • #23
                  I'm afraid not - it's not implemented for the moment. That's why we suggested to use the triplanar texture instead.
                  • #24
                    Hey, thanks Vlado. Ok, so how would I use triplanar mapping with Glossiness input on GPU? Is the setup I showed in the last image not it? I really appreciate the help.
                    Logan
                    Omnia Mutantur
                    logan683@gmail.com
                    Origin Genesis Pro
                    -i7 4790K @ 4.5GHz
                    -32GB RAM
                    • #25
                      I'll ask Andrey to check tomorrow; not sure what's going on right away.
                      • #26
                        That's really cool. Thank you for looking at this. I'm really excited about getting to use this feature.
                        Logan
                        Omnia Mutantur
                        logan683@gmail.com
                        Origin Genesis Pro
                        -i7 4790K @ 4.5GHz
                        -32GB RAM
                        • #27
                          I just exited Blender and this came up. I don't know if it tells you anything or not, but I thought I would put it up.
                          Logan
                          Omnia Mutantur
                          logan683@gmail.com
                          Origin Genesis Pro
                          -i7 4790K @ 4.5GHz
                          -32GB RAM
                          • #28
                            Try using "Output" texture as the converter (it has "Out Intensity" output).
                            andrei.izrantcev@chaos.com
                            Support Request
                            • #29
                              Thank you, bdancer. Can do. Just to be clear, would it go between the Image Texture node and the Triplanar, or between the Triplanar and the VRayMtl BRDF?
                              Logan
                              Omnia Mutantur
                              logan683@gmail.com
                              Origin Genesis Pro
                              -i7 4790K @ 4.5GHz
                              -32GB RAM
                              • #30
                                Sorry. Between the Triplanar and VRayMtl BRDF. By the way, is there somewhere I can read about the Output node? There's nothing in the documentation about it.
                                Logan
                                Omnia Mutantur
                                logan683@gmail.com
                                Origin Genesis Pro
                                -i7 4790K @ 4.5GHz
                                -32GB RAM
