is there somewhere I can read about the Output node?
Triplanar Mapping Problem
Originally posted by bdancer View PostBasically it's only used for such conversions.
All the documentation says is one thing about the Color to Float node:
"This node allows you to convert and RGB color to Float Color."
This is probably something I should know, but why would that be done? For normal map operations, I guess?Logan
Omnia Mutantur
logan683@gmail.com
Origin Genesis Pro
-i7 4790K @ 4.5GHz
-GeForce GTX Titan X @ +200 GPU, +300 Memory x2 non-SLI
-32GB RAM
-Windows 10 Professional 64-bit
All the documentation says is one thing about the Color to Float nodeLast edited by bdancer; 16-02-2016, 04:41 AM.
I see. Thank you for that and for helping me clear this Triplanar thing up. You do awesome work.Logan
Omnia Mutantur
logan683@gmail.com
Origin Genesis Pro
-i7 4790K @ 4.5GHz
-32GB RAM
JuhaW, tnx! Texture mode control was missing in the UI (fixed https://github.com/bdancer/plugins_d...c5a4cab32764df)
JuhaW, on node's N panel properties there is a control "consider same object only", try un-checking it.
JuhaW, have you updated the exporter? If so then this control is already on a node.
JuhaW, try updating again, sry =)
Thank you, now it works with different objects,like Vlado's post: https://plus.google.com/+VladimirKoy...ts/BrDyrirM4nf
Win7 Ultimate 64bit, GTX 970, Standalone version: V-Ray Next 4.30.03,
