IES lights not working
  • IES lights not working
    Settings - spot light choose IES profile = just soft light
    Does it work if you disconnect the node from the object?
      Are you talking about temperature node? No anything i do same result
        i think it might me broken in current builds
          Ah, I'm on an older build, didn't realize the 2.79 builds are still getting updates.
            im on latest cause animation doesnt work on older builds
              looks like it works with different IES files but no control over power/intensity though.
                Power is in lumens and ordinary home light bulb is around 500-1000 lumens.
                Win11 Pro 64bit, GTX 970, Standalone version: V-Ray Next 4.30.03,
                  i have tried 0 value and it is same as 10000
                    0 is the default power from the IES profile is used, says tooltip. Its very easy to test if power value is working, put power 1000 and again 1000 000.
                    Left IES-light power is 1000, right IES-light power is 500 000.
                      i see but still no difference 1000 and 1000000
                        Share .blend file and ies-file so we can test also.
                          Thank you all for support - the issue was that auto expousure was enabled, started it used recently and forgot about it.
