Displacement and multi UV: problem
  • Displacement and multi UV: problem
    I have a problem with displacement and multi UV.
    I have a material on a object.
    The diffuse map use the first uv set and the displacement a second UV set.
    Setted in this way the displacement still continue to use the first.
    If a switch that texture as bump or diffuse with the second UV set, all work fine.
    Anyone with this problem?
    Re: Displacement and multi UV: problem
    This could be a bug. A need to add some controls as a workaround - will do it in a few days.
    Try using Outliner in Datablocks mode as a quick workaround:
    andrei.izrantcev@chaos.com
    Support Request
      thank you.
      I'll try.
      After posting I thought another workaround: I could put displacement map on the first UVset and diffuse and other maps on the others UVsets... but your are better
