32bit Displacement Clipping
  • 32bit Displacement Clipping
    I've been doing quite a lot of experimentation with 32-bit displacement and it looks like the negative colors gets clipped
    there is a checkbox called "Allow negative colors", under Texture/Bitmap, that sounds like it should fix this but it doesn't seem to work.
    heres the test file:
    http://www.kjartantysdal.com/lagrings/3 ... or_bug.zip
    Hope this is a clear and easy to understand, if not then i can try to explain clearer.
    thanks
    http://www.blendernetwork.org/member/kjartan-tysdal
    Re: 32bit Displacement Clipping
    Yes, it seems to be a bug. I confirm that negative colors exist in this texture and vray is not able to read these values.
      Under "Influence" panel set "Blend" to "None" - this will fix the issue.
      This is because all textures are blended by default to their correspondent colors, but accidentally this as also done to displacement texture, I'll fix it a little later and by now use the workaround.
      andrei.izrantcev@chaos.com
      Support Request
        That's nice. Thanks for looking into it
