I am using the latest VB30 build as of 8/13, but this has been an issue from at least June (Sorry for not posting earlier, just busy) When I save a render as a .png file the image is partially transparent. Here is an example, one image saved as jpg (correct) and one as png (semi-transparent) Is there a setting in the output tab that I need to switch? I've updated vray standalone since, but maybe there's newer updates? What's going on?
why is my render partially transparent when saving as png?
Is this with autosave or when saving manually? Autosave seems to work fine for me in vray 3.
Andybot_cg, I think the problem is not the format png you are saving neither the alpha. The issue you are having is with Gamma and color mapping. Look for linear workflow in vray info so you can understand properly how to save your images and don't washed out afterwards.
Check this tutorial http://www.aversis.be/tutorials/vray...orkflow_01.htm
Hope it helps, greetings
