FOG - Operation
  • FOG - Operation
    Hi Forum,
    can anybody help me with the Environment Fog settings?
    I´m trying to create a fog like in this Photo.
    No matter what I do I dont even come close the the mood of the picture.
    I thought a noise in the Fog Transparency > Texture slot could bring me to the goal but it seams that nothing happens if I use a Noise.
    Did I forgot something or do anyone know a Tutorial where I can learn to handle the Fog Tool?
    Thanks for any help.
    Rick
    Im not sure how to get the detail and density youre after with env fog, but I was playing with it today to get some smokey stuff surrounding area lights. This was in Maya but I plugged 3d textures into the fog colour instead of transparency. It took way way longer to render connected to transparency. I also had to spend a while dialing in the scale of the noise as by default it can come in way too small which also kills the render time.
    Website
    https://mangobeard.com/
    Behance
    https://www.behance.net/seandunderdale
      I increased the Noise to 500% still no change, do I need to increase more?
      OK, I found a solution.
      A Noise in FOG Density (not in FOG Transparency) works BUT I have to increase the noise 20000% and higher
        I was using Maya, so Im not sure how it translates to cinema 4d...but if I used one noise, it needed a scale value of 40, if I used a different one, it needed a scale value of 0.1. So it really depends on the type of noise youre plugging in. I would make a very simple scene first, of just a light in some fog, and just get the system working on a very small and fast test scene. Attached is a screen grab from my test scene...it looks nothing like what youre trying to do, but I needed to try a lot of different scales to get one that worked. You could also plug in a checker material in the fog so you know for sure that the effect is working.
        Website
        Behance
          Originally posted by Rickmc View Post
          Hi Forum,
          Rick
          Hi Rick,
          here is a quick test, I've scattered a few trees from Cosmos library over a landscape object, for the fog I use some free clouds VDB files.
          In case you want to try this option remember to rise the render/shadows step percentage to speedup the render
          3D Scenes, Shaders and Courses for V-ray and Corona
          NEW V-Ray 5 Metal Shader Bundle (C4D/Max): https://www.3dtutorialandbeyond.com/...ders-cinema4d/
          @3drenderandbeyond on social media @3DRnB Twitter
            Mapping fog density was so much slower than mapping the colour, but if it works for you, thats cool!
            Website
            Behance
              Here is another test using environment fog with a couple noise layered inside the fog color:
                One last test, if needed I can upload the fog setup:
                Click image for larger version  Name:	test fog3.jpg Views:	0 Size:	278.8 KB ID:	1128442
Name:	test fog3a.jpg
                  Hi, that looks great.
                  I´m gonna try that the next days.
                    Would be nice, I need a similar set up for a work and I dont know how to get it because I dont use this kind of effect usually.
                      Hi Juan,
                      here is the scene, you need to download object Red Spruce 002 and 003 from the Cosmos library
                        Thanks very much, Sirio, I will study your set up.
                        Thaks again!
                          You are welcome
                          Be aware that is just a quick test, it can be improved a lot.
                            You are welcome
                            Ok Sirio, I will study your scene
                            Thanks again!
                            • #15
                              Thank you guys
