Tuorial about realistic cloudy fog
  • Tuorial about realistic cloudy fog
    Hi out there,
    does anybody knows a good tuorial about realistic cloudy fog. If you compare fog possibilities with U-Render it is unbelievable, how long it takes to get good result - I even have none.
    Cheers
    Tobias
    You can put a noise inside the environment fog and it will be perfect for this task, if you can show an image of what you need it will be easier to help.
    3D Scenes, Shaders and Courses for V-ray and Corona
    NEW V-Ray 5 Metal Shader Bundle (C4D/Max): https://www.3dtutorialandbeyond.com/...ders-cinema4d/
    @3drenderandbeyond on social media @3DRnB Twitter
      I want to create a noisy groundfog, like preseting something on a stage.
      Cheers
        steilvorlage.de something similar to this?
          Yunal beat me this time
          I suggest you to study the documentation to understand all the settings. Here are a couple examples, you can choose other noises and tune every detail:
          Click image for larger version  Name:	Schermata 2022-02-03 alle 14.49.11.png Views:	0 Size:	945.5 KB ID:	1138844Click image for larger version  Name:	Schermata 2022-02-03 alle 14.50.46.png Views:	0 Size:	845.0 KB ID:	1138845
            Thank you both for your fast response. Yes, both are great. I will try to use your settings. Somebody in the forum wrote to change the fog color, not density. Hope the rendertimes are ok.
            Thanks and cheers
              My tests took a few seconds on an 8core machine, don’t forget to tune the step size and if needed add a fade out.
                Ok, you have to turn of GPU-rendering, then you can use raymarching, and then the rendertimes are ok.
                  I don't know how you guys are working with the fog and IPR. Any time I add noise to any of the density/transparency/colour channels, the IPR just freezes up for about 5+ minutes, sometimes longer (fadeout just chews on it forever). I've wasted hours trying to experiment with different noises and it's just unworkable for production. It's not like I've got a slow machine either – it's a maxed out 2019 Macbook Pro:
Name:	Screen Shot 2022-07-03 at 21.54.42.jpg
                  We've got new Mac Studios being built this week, so it'll be interesting seeing how those fare.
                    Hello KernitTheFont,
                    Does this freeze only occur when tweaking the fog parameters? Is it only the interactive rendering that is freezing? Can you interact with Cinema4D's UI during the freeze? Also, can you specify the exact versions of V-Ray and Cinema4D that you have installed? Thank you.
                    Aleksandar Kasabov
                    chaos.com
                      Hi aleksandar.kasabov
                      Yes, just when I've added noise to the channels. Changing the fadeout values is even worse. I tried adding the noise to a Vray Bake texture, set to 8bit greyscale float, but that didn't help.
                      Yes, just super blocky for anything from 15seconds to 1minute with 'Preparing Ray Server' constantly in the IPR. If I move the camera, same problem.
                      Yes, works as expected.
                      I'm on r25.117 and Vray 5.20.05
                      It does seem a bit faster this morning, from a cold machine. Am I just being impatient? Here's the file: https://tandp.egnyte.com/dl/9mre8iD1wg
                        KernitTheFont , would you please try to use a higher Step Size value and see your the setup behaves on your system?
                        Btw value of a 1 cm for such a big volume and camera distance/position doesn't seem necessary
                          Yunal, you are an absolute legend! I've only just started trying to use fog in a scene and I didn't even think about the step size. I just left it at default. I'm experimenting for a misty environment in another big scene, so this info is invaluable.
                          Thanks so much!
                            Haha Don't know about that, but happy to help!
                            this might be a good pointer for us to revisit some defaults, thanks!
