How can I avoid repeating pattern on large areas? For example, I'm trying to fill a huge parking lot with gravel. I'm using a seamless image but I still can see the repeating pattern.
Texture: How to avoid repeating pattern on large areas.
Hi it_refplus - have you tried using the V-Ray UVW Randomizer? Its main intent is to offset, scale and rotate the texture based on its tiles (or polygon selections, or other properties) and I believe you should be able to reduce this repeating pattern.
Here is more info on how you can use it: Classic Shader and Node Material Context. I hope this helps you achieve your expected result.
- Likes 2
Originally posted by it_refplus View PostHow can I avoid repeating pattern on large areas? For example, I'm trying to fill a huge parking lot with gravel. I'm using a seamless image but I still can see the repeating pattern.
https://www.youtube.com/watch?v=I4sGJqO1194
there are also other techniques that will guarantee even better results but they will require more manual work.
3D Scenes, Shaders and Courses for V-ray and Corona
NEW V-Ray 5 Metal Shader Bundle (C4D/Max): https://www.3dtutorialandbeyond.com/...ders-cinema4d/
@3drenderandbeyond on social media @3DRnB Twitter
- Likes 4
