Invisble objects when using symmetry
  • Invisble objects when using symmetry
    Hi
    Vray 5 still has issues with instancing / symmetry?
    Is this Vray or c4d problem?
    When rendering symmetry, vray does not render the bolts visible in editor - even when I turn them editable from instances:
    (I can't find a workaround other than wasting time setting up unnecessary instances)
    Click image for larger version  Name:	symmetry_vray.png Views:	0 Size:	239.5 KB ID:	1107967
    www.rwvision.com.pl
    Hi RwVision, if the geometry is visible in the viewport, then it is likely a V-Ray issue. From my simplified tests, I found there is a problem when there are geometry objects with the same name and the scene is rendered either with V-Ray interactive or in the viewport (either with region or full).
    Can you test if either changing the geometry name of duplicating polygon objects or rendering in PV or V-Ray production solves the issue? Even if it does, I'll log an issue to investigate what causes this, but it may be a viable workaround until we fix this.
    Deyan Hadzhiev
    Developer
    chaos.com
      Hi deyan.hadzhiev
      Thanks for the reply - yes, geometry is visible in viewport, but not in rendering:
      - Changing names of the instances did not work
      - When rendering to pv the bolts are visible
      www.rwvision.com.pl
        same here .. very easy scene with cubes. rendering in the viewport is not correct: objects are missing (randomly). rendering in the picture manager works.
        but its importent to check complex scenes in the viewport. in my case every object has a different name!
Name:	test symmetry.jpg
        I can share the scene if needed.
          Hello klex167 and apologies for the delayed reply.
          It would be helpful if you can share the test scene with us. Also, please let me know which version of V-Ray do you have installed. Thank you.
          Aleksandar Kasabov
          chaos.com
            Hi Aleksandar,
            thank you for the reply!
            My version is hotfix 3 (v5.00.45 from Apr 27 2021).
            Scene in the attachent.
            best - klex
              Hello klex167 ,
              Thank you for the scene. It seems like this issue only happens when the instanced object is a null with children objects. For example, if you directly instance the cube the issue is no longer reproducible. I have logged this in our internal bug tracking system (bug ID: VC4D-976) and I will let you know once we have any updates.
              Aleksandar Kasabov
              chaos.com
                Understood. But the null is important to group more than just one object (like RwVision does). My example scene is just a very simple version of the original one where I had to cope with this issue. Thanks for working on this.
                Until the problem is solved I will avoid symmetry-objects and use instances with negative scale instead.
