Velocity Pass not working?
  • Velocity Pass not working?
    Has anybody had any joy using the Velocity pass channel with RSMB in After Effects? I've had to render a separate native C4D motion pass which is a bit annoying.
Name:	Screen Shot 2021-06-22 at 18.15.53.jpg
    Hello KernitTheFont ,
    What is the max velocity that you have set in the Velocity RE? Please try something like 90, disable the "Clamp Velocity" option and see if that helps. Can you please share a simple test scene and the AE project file where the issue is reproducible so we can have a look? Thank you.
    Aleksandar Kasabov
    chaos.com
      It was set at the default of 1.
      It straightened out some of the funkiness, but still blurring in the wrong direction.
      Sent.
      Thanks Aleksandar.
        Hi Aleksander/Chaos Devs,
        Any update on this issue?
        Thanks,
        Tim
          if I remember correctly I had to subtract 0.5 from the velocity pass.
          edit: but that was in Fusion I think.
          Marcin Piotrowski
          youtube
            Thanks,
            Tim
            Hey KernitTheFont ,
            Sorry for the late replay Alex is out of the office and I started looking in to your case. I'll update you as soon as I check the scene. Thank you for your patience!
            Ivan Shaykov
            chaos.com
              Hi shaio, any update on this? Still not getting a usable velocity file out of Vray for RSMB and I'll be needing it soon.
