Cosmos
  • Cosmos
    Dear Vray,
    Absolutely awesome that Cosmos is about for C4D.
    Though I don't get it to work. When I click on download, nothing happens. Am I missing something?
    Thanks.
    Yes, cool it is implemented, thanks!
    But same here... cosmos browser can't connect..
      Hey everyone,
      The cosmos browser comes bundled with the V-Ray for Cinema 4D installer. If you're using zip installations of V-Ray not the regular ones, then you need to download the cosmos browser separately. Please refer to our documentation page for Chaos Cosmos or the V-Ray zip installations, where you will find information on how to install the Chaos Cosmos browser.
      Ivan Shaykov
      chaos.com
        Great, it works... thanks a lot... is really fun to play around with it..
          I've just uploaded a quick tutorial about Cosmos usage in Cinema4D:
          https://www.youtube.com/watch?v=Mitdnvwn1Sg
          It's just amazing, you can build a scene in no time! thanks to all developers
          3D Scenes, Shaders and Courses for V-ray and Corona
          NEW V-Ray 5 Metal Shader Bundle (C4D/Max): https://www.3dtutorialandbeyond.com/...ders-cinema4d/
          @3drenderandbeyond on social media @3DRnB Twitter
            Just downloaded and installed, used the installer. Unfortunately, when I try to download any item, the information appears that there is no access to the download directory.
Name:	Zrzut ekranu (10).png
              You need to login first see my video at 24''
                I am logged in, and still not working.
                Click image for larger version  Name:	Zrzut ekranu (11).png Views:	0 Size:	199.9 KB ID:	1123835
                  Have you installed Vray update using the installer?
                    Yes, I used the installer.
                      Did you set a download folder.
                      I had the same, after setting a download folder it worked.
                      Click image for larger version  Name:	Screenshot 2021-09-02 22.18.16.png Views:	0 Size:	64.0 KB ID:	1123841
                      Click image for larger version  Name:	Screenshot 2021-09-02 22.18.27.png Views:	0 Size:	21.7 KB ID:	1123842
                      Try a new folder… I had problems with permissions…
                        Yes probably it's the permissions, I've only installed on MacOS and the system asked access to the folder. It should be the same for Windows, I'll try that tomorrow on a PC.
                          Thank you, it helped.
                          Works now, after manually setting the downloads folder.
                            I cannot seem to sign in... installed the latest vray 1.2 + cosmos seperately.
                            • #15
                              Hey MichaelLammens,
                              Have you tried uninstalling and installing back the Chaos Cosmos Browser?
                              Did you have a previous Cosmos installation (i.e. from another host-app)?
                              Best would be to forward us the cb.log file located in C:\Program Files\Common Files\ChaosGroup\ChaosCosmos so we can check for any errors printed. You can send it via our contact form, just make sure to mention this thread (or my name) in the form subject. Much appreciated!
                              Nikoleta Garkova | chaos.com
