Vray_3.7 Fix light spots during rendering
  • Vray_3.7 Fix light spots during rendering
    Can someone please help me , as seen in the picture i have a light band that is bordered and shines down. but unfortunately it shines up through the element. i don't know where i can correct it in the rendersettings anymore. Somewhere in the GI or ? Please help
    THX
    If you share the scene I can check that for you, I just need the essential to reproduce the issue.
    3D Scenes, Shaders and Courses for V-ray and Corona
    NEW V-Ray 5 Metal Shader Bundle (C4D/Max): https://www.3dtutorialandbeyond.com/...ders-cinema4d/
    @3drenderandbeyond on social media @3DRnB Twitter
      Hi Sirio
      Is it ok if I send it to you at this address: info@3dtutorialandbeyond.com ?
        Scene received, I’ll check it out in the afternoon
          Hello alex_obrist
          Can you please provide me with the scene file along with all associated assets so we can also investigate the issue?
          If you prefer to not upload the scene publicly on the forum, you can open a ticket via our contact form and mention this forum thread.
          Valentin Leondiev | chaos.com
            Hello alex_obrist
            The issue with the light bleed was due to the Irradiance map. There are a few ways you can resolve the issue.
            So far the easiest way is to enable to detail enhancement of the irradiance map under Global Illumination > Irradiance map> Detail Enhancement.
            Another way to solve the issue is to switch the primary Global Illumination engine to Brute Force. That will generate the most accurate lighting result, as V-Ray will trace the primary lighting rays. However, this will increase the render time and I found it to produce a noisier image overall.
            You can deal with the noise by increasing the bucket sampler max subdivision and lowering the threshold value, which can additionally increase the render time. A simpler solution would be increasing the radius value of the Antialiasing Filter. That will help with the noise but can blur your image a bit. I found out that a value of 2 works well.
            You can find more information about the GI engines on the following articles: https://docs.chaosgroup.com/display/...tion+Reference
            Brute Force: https://docs.chaosgroup.com/display/VC4D/Brute+Force+GI
            Light Cache: https://docs.chaosgroup.com/display/VC4D/Light+Cache+GI
              Many thanks for the help Valentin !
                Hi I've answered to your email
