Sometimes UV Issue
  • Sometimes UV Issue
    sometimes I have a problem with UV. Sometimes the order of material and UV is important. Not always, not on every scene.
    But would like to know the reason, as I have a file with a lot of elements imported, where this behaviour is mixed...
    Please take a look the screenshot. File with one object attached
    Thanks..
Name:	Screenshot 2021-10-07 08.58.57 copy.jpg
    Hi haniel1107 ,
    I downloaded the scene, but could not get the same error you had.
    Btw a good rule of thumb would be having a somewhat proper UV layout and staying away from the overlapping techniques, unless it's an asset meant for game engine and you want to save some resources.
    Hope this helps
      Hi Yunal,
      thanks, for the tip, but this is an object out of a large turbosquid scene.
      I am using last nightly build of vray5, win 10 S24.
      BTW when you duplicate the object the error won't appear on the duplicated object... only if you move the uv tag on this object I've sent.
      Thanks,
      hani
        Hello haniel1107,
        Upon testing, I managed to reproduce the same issue. It looks like it happens when the UVW tag is placed after the material tag. If the order is changed, the issue is not reproducible.
        I have now reported this to our developers (bug ID: VC4D-1119) and I will let you know once we have any updates on the matter. Thanks.
        Aleksandar Kasabov
        chaos.com
          Happy you could reproduce it. Thank you!!
            Hello deyan.hadzhiev or CG, do you know when this could be fixed. Or is there a trick or script I could use.
            For example, I have a scene here with over 5thousand objects where the uvw tag is placed after the material. This happens when you import from maya ... I can not work on my clients request before I have brought all uvw in place...
            As you can imagine, this is really bad... and costs me a job
            Help or a fix is much appreciated and urgent..
              Hi haniel1107 , we are sorry for the inconvenience. This issue is a top priority at the moment and the fix is almost ready. We hope to have it available in the stable builds next week.
              Deyan Hadzhiev
              Developer
              chaos.com
                Hi deyan.hadzhiev, thanks for your quick response... and of course as early as possible would be fantastic... Thanks a lot!!
                  deyan.hadzhiev
                  And let me please add another request here... maybe you could consider to make a hotfix with it, as alone this bug is a hotfix worth, otherwise renderfarms like rebus will ignore this fix... ???
                    Hey haniel1107 ,
                    Yes, we plan to make a hotfix with this issue fixed as soon as possible.
                    Ivan Shaykov
                    chaos.com
                      Hi shaio , thank you!!!
                        deyan.hadzhiev thanks for the update this night!!!
                          Hello haniel1107,
                          As you have probably already noticed, this issue (bug ID: VC4D-1119) has been fixed and the fix can be found in our latest stable build. You can download it from here:
                          https://nightlies.chaosgroup.com/mai...table/20211026
                          Aleksandar Kasabov
                          chaos.com
                            aleksandar.kasabov yes thank you, I am already using it...
