Symmetry Object problems
  • Symmetry Object problems
    Am I the only one to whom elements don't render if they have the same name within a Symmetry Object.
ID:	1127114Click image for larger version
ID:	1127115Click image for larger version  Name:	Screen2.JPG Views:	0 Size:	9.6 KB ID:	1127112
    The issue is know. See the link. I'm avoiding to use the symmetry object. Usually I make an instance and scale it to -1.
    Hi Vray 5 still has issues with instancing / symmetry? Is this Vray or c4d problem? When rendering symmetry, vray does not render the bolts visible in editor - even when I turn them editable from instances: (I can't find a workaround other than wasting time setting up unnecessary instances) Click image for larger version
      Same here, the render instance option is also more efficient for both viewport and RAM usage so I do that regardless of the symmetry issue.
      3D Scenes, Shaders and Courses for V-ray and Corona
        Does it not cause normal flipping (bumps on the wrong side etc.)?
          No, at least in render instance mode the normals are fine.
            As klex167 already mentioned above, this is a known issue (bug ID: VC4D-976), that has already been reported in our system. I made sure to also mention this thread and I will let you know once we have any updates on the matter. Thank you.
            Aleksandar Kasabov
            chaos.com
