V-Ray for C4D does not render material in cloner
  • V-Ray for C4D does not render material in cloner
    Hello! I faced a very strange issue. V-Ray does not render materials on cloned objects. In IPR it works well. I'm set up default geometry to dynamic in settings — it does not help. I will attach the video and .c4d files.
    https://imgur.com/a/igNP4P4
    https://drive.google.com/file/d/1BK-...ew?usp=sharing
    Hello alexey_golod,
    Thank you for highlighting this for us.
    This seems like a bug and I have reported it to our developers for fixing (bug ID: VC4D-1334). I will let you know once we have any updates.
    Until then, a workaround would be to render your scene with V-Ray GPU where the issue isn't reproducible.
    Aleksandar Kasabov
    chaos.com
      Hello aleksandar.kasabov! Thanks you! But on GPU there is another problem — UV does not renders correctly.
      https://imgur.com/a/0ta4pRS
        Hi alexey_golod, we will be looking into this issue. In the meantime - using render instance or multi instance mode for the cloners should also work and even be faster to export and render. Is there a particular reason for using the default "Instance" mode?
        Deyan Hadzhiev
        Developer
        chaos.com
          Hello alexey_golod,
          Please note that this bug (bug ID: VC4D-1334) was recently fixed by our developers and the fix is available in our latest stable build. You can download it and install it from here.
          Aleksandar Kasabov
          chaos.com
