Texture Mapping on extrude-nurb doesn´t work with GPU
  • Texture Mapping on extrude-nurb doesn´t work with GPU
    Mapping on Extrudenurbs is always UVW when I render on GPU. No matter what kind of mapping I choose or what scale I use. When I convert the objekt and erase the UVW tag it works.
    Hi dirk_laggner and welcome to the forum,
    Could you please explain your workflow for using the ExtrudeNurbs, and your use case. A simple example will be helpful to us
    Thank you and have a nice day!
    Best,
    Muhammed
    Muhammed Hamed
    V-Ray GPU product specialist
    chaos.com
      Hi Muhammed,
      just a standard rectangle in the extrude with standard height. Put material with texture on it, change to quadric mapping for example and change the size. When I render with CPU everthing is fine with GPU always UVW mapping with standard size is rendered.
      regards,
      Dirk
        Hello dirk_laggner,
        Thank you for highlighting this for us.
        I managed to reproduce the issue on my end and I have reported it to our developers for fixing (bug ID: VC4D-1380). I will make sure to notify you once we have any progress. Thanks!
        Aleksandar Kasabov
        chaos.com
          Hey, Dirk,
          Thank you for the feedback and report. I want to offer you two workarounds that work with procedural geometry and are available within the latest official build.
          1/ Use V-Ray Bitmap texture and control the texture via mapping tag
          2/ Use Projection shader with texture map, which has more controls.
          Of course, I understand that is more work, and I hope this behavior won't be a bottleneck in your workflow. Please let me know if something is not correct.
          Cheers,
          Boyan Nalchadjiiski | QA Engineer @ Chaos |
          E-mail: boyan.nalchadjiiski@chaos.com
            Hello dirk_laggner,
            Our developers have fixed this bug and the fix is now available in the latest stable build.
            You can download it and install it from here.
            Aleksandar Kasabov
            chaos.com
