We have found a bug that unfortunately forces us to switch back to the VRay5 version. If the camera is set to Spherical and you use a Stage object then it can happen that the VRay Cameratag is not used when changing the image. Here is an example file that shows the problem:
Stage_Spherical.zip
It is not caused by the Python script, it happens even if the cameras are keyed normally.
The error only occurs in VRay6. In VRay5 everything still works fine.
Both versions were tested on the S26/Windows.
Stage_Spherical.zip
