Missing vray6.1 standard material shader
This topic has been answered.
  • Missing vray6.1 standard material shader
    As shown in the picture, 6.1 lacks several shaders compared to 6.0. Is this a bug?
  • Answer selected by viktor_angelov at 25-05-2023, 12:35 AM.
    Hello 123456_
    The mentioned V-Ray textures are currently unavailable.
    Please, be aware that the textures can be used with V-Ray Node Materials.
      Hello 123456_
        Originally posted by viktor_angelov View Post
        Hello 123456_
        I understand. Will it be restored to use in the future? After all, it will be faster to use standard materials for some simple materials
          We appreciate your feedback and will keep it in mind. Unfortunately, we are unable to disclose anything at the moment.
            Please if possible add also the Vray color correction in standard material
            3D Scenes, Shaders and Courses for V-ray and Corona
            NEW V-Ray 5 Metal Shader Bundle (C4D/Max): https://www.3dtutorialandbeyond.com/...ders-cinema4d/
            @3drenderandbeyond on social media @3DRnB Twitter
              Hello sirio76
              To color correct in V-Ray Standard Material you can use the Filter. Simply add it from the dropdown menu and you will be able to adjust the Hue, Contrast, Brightness, Enable Gradation Curves and more. Refer to the screenshot for more information: http://ftp.chaosgroup.com/support/sc...6_10-18-03.jpg
                Hello sirio76
                I know about the filter option, I still think it would be a better option to have an “uniform” color correction system that act the same in both standard and node editor. Having totally different options between the two system may result confusing, especially for less expert users.
                Ideally we should have the same feature set between the node and the standard material system, and choose one or the other depending on our needs.
                  Thank you for the feedback, sirio76. I have shared your request with the team and it will be taken into consideration.
                    Search for this material in Chaos Cosmos and you will get color correction. The vray seems to have hidden many shaders
                      I know this is used for some Cosmos assets, but it should be available in the shader list rather than be hidden.
                        Hello 123456_
                        Would you give us some feedback regarding the unavailable textures? Why do you want them specifically to be supported?
                          Hello 123456_
                          For example, if the textures are not hidden, they can be used on displacement
                            Would you let us know why do you prefer using those V-Ray Textures instead of Cinema 4D's native textures?
                              The V-Ray texture compensates for some of the shortcomings of the Cinema 4D native texture, just like this texture used to make broken glass. It seems that this texture cannot be achieved in the Cinema 4D native texture
                              • #15
                                Thank you 123456_
                                These examples are highly appreciated as they help us understand what the users expect. Please, do not hesitate to share more if any.
