render mask problem
  • render mask problem
    hi, I encountered a problem with the render mask function.
    if I launch the whole image no problem but with the render mask it is blurry and with a loss of a lot of detail. Even with Denoise turned off. this happens with vray 6.1 on win10​​
    Hey, visualtracing,
    Thank you for submitting your report. It is normal to see a difference in quality between a bucket/progressive aka final render and an interactive one. However, if you see a difference between two final renders, please inform us and provide us with additional information, including a scene file.
    Cheers, ​
    Boyan Nalchadjiiski | QA Engineer @ Chaos |
    E-mail: boyan.nalchadjiiski@chaos.com
      HI
      the two images are two final progressive renderings, non-interactive.
      However, this evening I will prepare a file to send you.
      Thank you​
        HI,
        I found the problem but I don't understand why.
        the problem is solved if I delete the second round carpet, I don't understand how much trouble it can cause though.
        Below you will find the two renders that are not interactive.
        link scene
        https://e.pcloud.link/publink/show?c...EGMiBUu7njvNmX
        thanks​​
        Click image for larger version  Name:	render.jpg Views:	0 Size:	830.2 KB ID:	1192041 Click image for larger version  Name:	render_mask.jpg Views:	0 Size:	382.4 KB ID:	1192042
          Hi visualtracing__,
          It seems like the issue is caused by this polygon selection tag. Removing the tag (or renaming it) seems to resolve the issue. I hope this is of help.
          Aleksandar Kasabov
          chaos.com
            Originally posted by aleksandar.kasabov View Post
            Hi visualtracing__,
            Thanks so much
