When using Decal, there is a strange shadow when Displacement is enabled.
  • When using Decal, there is a strange shadow when Displacement is enabled.
    I don't know if my usage method is wrong. I only gave black and white textures to the mask and displacement.
    Hello qingyuan_pang You should be able to do this by using the V-Ray Bump Material. Please, refer to the video recording: http://ftp.chaosgroup.com/support/sc...7_07-30-41.mp4
    Also tested the Decal Displacement option and it seems to work as expected: http://ftp.chaosgroup.com/support/sc...7_07-35-36.jpg
    If this does not work for you, please, send us the scene so can investigate further.
      Click image for larger version  Name:	LionHead_Decal.png Views:	37 Size:	63.7 KB ID:	1195796
      Click image for larger version  Name:	Snipaste_2023-11-25_14-00-57.png Views:	39 Size:	1.84 MB ID:	1195797
      Is possible that displacement settings are not ideal to produce enough subdivisions on the surface, try to pre-subdivide the mesh in square of 10x10cm, maybe rise the edge length to 2 or 1 to get more detail.
      3D Scenes, Shaders and Courses for V-ray and Corona
      NEW V-Ray 5 Metal Shader Bundle (C4D/Max): https://www.3dtutorialandbeyond.com/...ders-cinema4d/
      @3drenderandbeyond on social media @3DRnB Twitter
