I'm working on a plugin, which is supposed to generate materials (amongst others) for Vray/C4D.
I'm using Vray 6.20.01.
All is nice and dandy in C4D 2023. But in 2024 my code fails to get the end node of a freshly created node material.
My code looks roughly like so (error checking removed just for this post):
While I'm also considering this to be a Maxon issue (or change), I do not see this issue with any other render engine I need to support (Arnold, Corona, Octane, Redshift all do work fine in 2024).
Any help would be much appreciated.
Thanks in advance,
Andreas
Code:
id_nodespace = "com.chaos.class.vray_node_renderer_nodespace" id_node_mat = "com.chaos.vray_node.brdfvraymtl" id_node_output = "com.chaos.vray_node.Material" ### Did this change? mat = c4d.BaseMaterial(c4d.Mmaterial) ref_mat_node = mat.GetNodeMaterialReference() graph = ref_mat_node.CreateDefaultGraph(id_nodespace) result = [] maxon.GraphModelHelper.FindNodesByAssetId(graph, id_node_mat, True, result) result = [] maxon.GraphModelHelper.FindNodesByAssetId(graph, id_node_output, True, result) ### Here I get an empty result list in C4D 2024, while it works as expected in C4D 2023
Thanks in advance,
Andreas
