Python: Finding material end node in C4D 2024
  • Python: Finding material end node in C4D 2024
    I'm working on a plugin, which is supposed to generate materials (amongst others) for Vray/C4D.
    I'm using Vray 6.20.01.
    All is nice and dandy in C4D 2023. But in 2024 my code fails to get the end node of a freshly created node material.
    My code looks roughly like so (error checking removed just for this post):
    Code:
    id_nodespace = "com.chaos.class.vray_node_renderer_nodespace"
    id_node_mat = "com.chaos.vray_node.brdfvraymtl"
    id_node_output = "com.chaos.vray_node.Material"   ### Did this change?
    mat = c4d.BaseMaterial(c4d.Mmaterial)
    ref_mat_node = mat.GetNodeMaterialReference()
    graph = ref_mat_node.CreateDefaultGraph(id_nodespace)
    result = []
    maxon.GraphModelHelper.FindNodesByAssetId(graph, id_node_mat, True, result)
    result = []
    maxon.GraphModelHelper.FindNodesByAssetId(graph, id_node_output, True, result)
    ### Here I get an empty result list in C4D 2024, while it works as expected in C4D 2023
    ​While I'm also considering this to be a Maxon issue (or change), I do not see this issue with any other render engine I need to support (Arnold, Corona, Octane, Redshift all do work fine in 2024).
    Any help would be much appreciated.
    Thanks in advance,
    Andreas
    Hi @andrew_price​ the asset id of our Material end node is "com.chaos.vray_node.mtlsinglebrdf" and should be the same across all V-Ray/Cinema4D versions. You can easily find the asset ids of ports and nodes in the node info by enabling it in preferences.
    Click image for larger version  Name:	image.png Views:	0 Size:	56.3 KB ID:	1203177
      Hi bozhidar_ivanov,
      thanks a ton. Not only for the provided ID, which is working nicely, but also for the hint that we can enable the ID to be shown in UI. Very helpful, I somehow missed that!
      You can consider this case closed.
      Thanks and cheers
        i also start to manage node material with python, and actually i'm stuck with finding a way to get and set value for a material parameter like "Material Id Enabled" checkbox
        When i drag and drop it in console i get parameter name: VRayMaterial["com.chaos.material_options.base.material_id_enabl ed"]
        But when i use this parameter name in my code i have this error: TypeError: GeListNode_mp_subscript expected Description identifier, not str.
        I'm a bit disapointed with this new node materials :/
          Originally posted by f2b View Post
          Hey,
          It seems that you are trying to use the old hierarchical material model to set up a new node material model, and you need to use maxon.GraphNode method to obtain new material models is much more complex than old materials.
          If you want to use artists in a good way to modify, you can try using GraphDescription.
          Cheers~
          DunHou
