The scene imported by vrscene is a four-sided surface when viewed, and a triangular surface when selected.
This topic has been answered.
  • The scene imported by vrscene is a four-sided surface when viewed, and a triangular surface when selected.
  • Answer selected by viktor_angelov at 20-03-2024, 01:11 AM.
    Hello qingyuan_pang The vrscene is optimized in a way that the final result, when imported and turned into an editable, is triangles. I have exported multiple objects from May, Max and Cinema and you can see that it works the same everywhere.
    Please, refer to the video: http://ftp.chaosgroup.com/support/sc...0_10-09-21.mp4
      Hello qingyuan_pang Thank you for reaching out to us!
      Does it happen with every vrscene you import or just this one?
      What Cinema 4D version and V-Ray build are you using?
      Where is the vrscene exported from?
        As far as I know this is true in all versions, I exported from 3dsmax
        https://nightlies.chaos.com/main#/vr....2/20240315​
          qingyuan_pang Please, share the vrscene with us so we can investigate. You can do that here or by Submitting a Request to our system: Submit a request
            please see Attachment
                Hello qingyuan_pang I wanted to let you know that you can transform the Triangles to Quads through Cinema 4D. Simply be in Polygon mode, select the object from the Objects menu but make sure to not select any polygons.
                Then do Right Click > Untriangulate. You would need to adjust the settings, mainly the angles. For example, for your vrscene I found an Angle of 10 works best: http://ftp.chaosgroup.com/support/sc...0_11-45-54.mp4
                  qingyuan_pang We have discussed the matter with the team and we have logged this into our system [VC4D-2239] We will look into the opportunity to implement it in the future.
                    Okay, thank you very much
