texOSL and mtlOSL Nodes broken c4d 2024.4
This topic has been answered.
  • texOSL and mtlOSL Nodes broken c4d 2024.4
    Hi All!
    Unfortunately i realized today that the texOSL and mtlOSL nodes are broken in the latest c4d 2024.4 and V-Ray 6 for Cinema 4D, update 2.2 (v6.20.02 from Apr 12 2024). I can see the node in the list of node elements but it can not be placed into the node editor ( both the texosl and mtlosl are broken). When i try to import a shader that has texosl node in it form c4d 2023 and an earlier c4d version the material brakes.
    In c4d 2023.2.2 and the same vray version it works!
    Please fix as soon as possible!
  • Answer selected by viktor_angelov at 21-05-2024, 12:03 AM.
    Hi akos_kiss
    The fix for the OSL nodes is only available in our stable nightly builds (builds from 9th of May or later contain the fix). You could use the stable builds until we include this fix in the next official release. About the crashes... There have been many ​internal changes in Cinema4D 2024 which also required some changes on our side, however, we haven't noticed any major problems. If you have any specific crashes or bugs feel free to post here or use our support system - https://support.chaos.com/hc/en-us/requests/new.​
      Hi akos_kiss, unfortunately due to changes in Cinema4D 2024.4 OSL nodes are indeed broken. We have already fixed this internally and will inform you once the changes are in our stable builds. Note that they are only broken in Cinema4D 2024.4 and should work in all previous C4D versions.
        bozhidar_ivanov Thanks for the reply! Are there any other thing that are affected with c4d 2024.4? WE started new projects in 2024 and transitioned some projects from 2023 and we were having strange crashes and bugs while rendering with vray. are there some other changes that are not mentioned in the release notes?
          Hi akos_kiss
            Hi : Thanks for the update! Currently we are in the middle of a few productions so we used the official releases. Next week i think i'll have some time to test the nightly builds and will get back to You! Regarding the crashes we are in contact with the you support system
