Problem with refraction max depth
  • Problem with refraction max depth
    I recently discovered a thread about the max depth issue in reflections in GPU rendering (GPU Production rendering ignores material reflection max depth when using metalness).
    It got solved 2019. I have kind of the same issue with refractions atm. Settings above a certain number get ignored (6-. Is there any workaround possible without switching to CPU?
    Thank you for your help
    Quick update: I was trying to replicate the issue on a new scene but it looks like its working as expected.
      Hi H_923874​,
      Can you please share the following information:
      • The versions of V-Ray and Cinema 4D you are currently using
      • A video demonstrating the problem or some screenshots
      • A scene file where the issue is reproducible.
      Please note that you can share all the information here in the forum, or submit a ticket in our support system if you prefer.
