Hello
When does the material converter for C4D materials come to Vray materials?
I work with Vectorworks and I have to convert all my materials by hand or with the old 3.7 version I know that C4D materials are supported but I also use Vantage and it would be great if I only used Vray materials.
The reflections and the bump channel do not produce the same results in C4D and Vray material.
If the geometry is changed in Vectorworks, I do a new handover because new C4D materials are then created which I can then only convert by hand, very time-consuming.
As you can see, this is not an optimal workflow!
And I think all other users would be very happy if a material converter came out and you don't have to work with two versions.
Thanks very much!
Thanks very much!
