Visibility of objects
  • Visibility of objects
    Hi, i want to ask if it is possible to add an visibility slider to the object tag of vray. It would be an benefit for animations where many objects with the same material but different visibility states will be rendered. Now is the workaround to make a Blend Material and set the opacity, but you need for every object its own blend material.
    Thanks in advance
    Matthias
    Hello matthias_illes,
    We already have a request for implementing this in V-Ray for Cinema4D (request ID: VC4D-829). This topic has also been discussed in this thread.
    I have your thread to the request and I will let you know as soon as we have any updates on the matter. Thank you.
    Aleksandar Kasabov
    chaos.com
      As I already mentioned in this thread, we have added an option to animate the visibility of an object with the latest stable build. This can be done with the Visibility parameter in the V-Ray Object Properties tag/ Visibility options.
      The latest stable build can be downloaded from here. Thanks.
      Aleksandar Kasabov
      chaos.com
