I want Vray to rule out reflection and refraction between two objects so let's say I have A, B and C and I want A not to reflect B but not to affect C reflecting B
  • I want Vray to rule out reflection and refraction between two objects so let's say I have A, B and C and I want A not to reflect B but not to affect C reflecting B
    It helps that some objects don't reflect unwanted things
    Hey,
    Thanks for the great question. Could please, assign the object properties (select the Item into Objects tab -> Right mouse button ->V-Ray Tag -> Object properties ) to all of them and Check the Visibility Option tab?
    Cheers,
    Boyan Nalchadjiiski | QA Engineer @ Chaos |
    E-mail: boyan.nalchadjiiski@chaos.com
      Originally posted by boyan View Post
      Hey,
      Cheers,
      If the label is used, the impact is global. As in the picture, the yellow ball is invisible on all models, and I want the silver ball to reflect the yellow ball. The green ball does not reflect the yellow ball
        Hi 123456_, we will be adding the include/exclude lists for object properties reflection and refraction shortly.
        Deyan Hadzhiev
        Developer
        chaos.com
          That was great
