Motion blur for changing geometry by v Attribute (forced)
  • Motion blur for changing geometry by v Attribute (forced)
    Hi everybody,
    Is there a way to force V-Ray to calculate Motion Blur by using the v attribute, instead of sampling the geometry?
    I didn't find an option to force it and as far as I can see, this is only done for particles automaticaly.
    An example case would be when you merge in geometry in a simulation. Currently this produces incorrect results with defaults.
    Or is there maybe another way?
    Cheers,
    Aleksej
    Aleksej Skrypnik | FX Artist | unexpected
    Hello Aleksej Skrypnik , yes you can use v attribute for calculating velocity blur. Just need to switch "Geometry Velocity Blur" to "Velocity Blur" in geoObject > Render tab> Sampling sub-tab
    Georgy Chakarov | QA
    www.chaosgroup.com
    georgy.chakarov@chaosgroup.com
      Works perfectly. Thank you!
